Well, It Didn't Start...
Hi everyone. Well, Pop's Truck was a little contrary this afternoon when I tried to fire it up for the first time. Of course I had the HEI distributor 180 degrees out of time to begin with. It was backfiring through the carb pretty badly. I have now gotten it (with correct distributor placement) to stop backfiring, but it still will not crank. It is very sluggish. Fuel pressure is around 6 psi into the carb and I have spark, hence the shotgun firing out of the carb. Any ideas? This is where I have absolutely NO experience. Ten pages of responses are welcome. I need ideas and I will systematically work through them all if need be. I would prefer however to not wipe out my cam before it gets broken in if I can help it though. Thanks in advance. I hope all is well.
It sounds to me you're doing everything right, but you may be too far advanced, try backing off a bit.
I agree with Montana Highboy, back off and take your time. I just went through all this a week ago. Double check timing, get it as close as possible before start up. I also have another starter on it's way. Mine turned over pretty slow, probably due to slightly higher compression and being new. Went with a high torque starter from Powermaster. You'll figure it out, it WILL come together.
Well, good news and bad news. The good news is the truck fired right up after I got the timing right. The bad news is the Dakota Digital gauges read 0 oil pressure. It ran for a few seconds before my helper killed the switch. I took the valve cover off and took a few pictures. There was oil in the bottom of the valve cover and the bottom of the distributor, but I don't know how much I should expect. Let me know what you think. Also, I am going to reprime the oil pump just to make sure. More ideas please...
Until you get things sorted out, I would use a mechanical oil pressure gauge. Even a "cheapie" would work, one less thing to sort out at the start.
Once you've got her running and have good oil pressure, then you can trouble shoot the digital gauges (unless they are accurate and you actually don't have any oil pressure).
Good luck Maul Maul, we're all "rootin' " for you.
on
Also, any engine I have seen without oil pressure gets some insane rattling from the lifters, and them not pumping up but just clattering up and down. Remove the oil filter (or loosen it) and see how much comes out. I know on my 545 I just did, it wouldn't pick up prime, spun it forever and no deal. I finally loosened the filter and it primed immediately and squirted oil everywhere.
