Heater suddenly quit working on 2000 V-10 Ex
on
The water level is up, the heater hose is hot on both sides of the heater hose bypass valve, the MtrCrft thermo is pretty new, but it blows cool air out the vents even after a half hour of driving. It was working great last week and then nothing. I guess you can see the blend door moving if you pop the glove box out?..........haven't tried that.
And sad too since all too many cars are the same story.
Just throwing a guess out there. Are the blend doors vacuum operated? If so, could you have a vacuum line off someplace?
on
I haven't gotten that far yet, I was just looking for some possibilities for now.
And here is one for the heater core (not too bad).
99-07 Ford Super Duty - Heater Core Replacement - YouTube
on
More clues
The hoses on both sides of the re-routing valve are hot and the one below is cold but is there another hose I should be checking? Also; there are 2 water pipes behind the heater core and the one on the left is very hot but the one on the right is cold, also; the cover on the heater core is cool to the touch. Also; the blend door rod and lever move up and down when you switch the heat from floor to dash.............but still no heat, it just pushes out lukewarm air. The rad tank is filled up the the max fill line and the top rad hose is hot to the touch.
Looks like the return from the heater core is cold in your picture. Might mean the heater core is plugged up. Or the valve isn't allowing full flow to the core. Even though the hose is hot right after the valve it still might not be flowing fully.
Turn the heater off and see if the hose out the bottom of the valve gets hot just to know the valve is at least working like it should.
on
When you shut the heater off (turn to cold) does the valve warm up along with the hose in and the hose out the bottom? If not and the radiator is warm I would be looking at the valve first. Especially since you said the heater was working good the other day. Normally when cores plug up they slowly get worse and worse, not just an over night thing unless a chunk of something blocks a hose.
on
I have a new valve coming from Amazon (with the bottom tube) and it was $35 with free shipping .....Motorcraft.
