1959 steering box
Old 04-24-2013, 08:48 AM
jamhh's Avatar
jamhh
jamhh is offline
1959 steering box
How did I tell what steering box my truck is equipt with. It looks like there could be three options. I can't see any casting numbers on or name on it?
the only casing no I can see are TAAK 3550 Ingersoll Machine
& how does the steering box separate from the steering shaft, it looks as it I have to take the steering wheel off and the shaft is part of the box? Is this correct
Old 04-24-2013, 07:04 PM
spurredon's Avatar
spurredon
spurredon is offline
Perhaps if you posted a pic of your box it would help. Not knowing what box it is makes it hard to answer your next question.
Old 04-25-2013, 07:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
How does the steering box separate from the steering shaft, it looks as it I have to take the steering wheel off and the shaft is part of the box? Is this correct?
1957/58 and 1960 F100/250 2WD have a Gemmer gearbox. Some 1959 F100/250's 2WD's have Gemmer, some have a Saginaw gear box.
The Gemmer box has a casting number of: 3CC31
Old 04-25-2013, 01:01 PM
jamhh's Avatar
jamhh
jamhh is offline
how do I post a picture successfully. I must be doing something wrong.
Old 04-26-2013, 06:16 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Originally Posted by spurredon
Perhaps if you posted a pic of your box it would help. .
I'm sooooo NOT going there!
Old 04-26-2013, 09:33 PM
economan's Avatar
economan
economan is offline
I'm guessing that as it is likely a cdn. production truck the "Ingersoll" steering gearbox could have possibly been made in Ingersoll ont "?!?" I just swapped the one on my 58 last weekend for a slightly better one. Both were Ingersoll's & yes you have to take the shaft out right up to the steering wheel. I can't remember if on a stock truck you can slip it out of the column without completely removing the outer column I couldn't get enough room cuz of the exh. pipe coming off of my small block's manifold, so I hadta take the outer column off. , but this gave me a chance to re bushing my auto shifter (57 ford car) and tighten up the shifting mechanisim.
mikie
near Ottawa Canada
58 merc panel & 64 econoline p/u
capelo
05-04-2016 03:50 PM
Steve Bennett
01-05-2016 08:06 AM
F250racer
Montana Chapter
04-30-2014 08:17 AM
eskew11
10-24-2004 10:10 AM
fordzrule
08-26-2001 05:44 PM
Quick Reply: 1959 steering box
