welding holes to make holes...
on
spent the last two hours trying to weld up holes in the firewall... it's like trying to weld up the holes in window screens..... fill one ... make one... even with my welder at it lowest setting I was still blowing thru... and if you really wanna have fun... put a patch plug behind the wall and hold it in place with a magnet... I've got so much welding wire sticking through the firewall on the inside it looks like a porcupine exploded in there... more grinding... goody
my body man will fix all the other little blowthrus with some nice "lite" glass... I'm done..
BTW... how many holes do you think I need ??? one for the brake booster, one for the throttle cable... one (somewhere) for the a/c hoses and one (somewhere) for electrical... oops... and one for the park brake cable...
what else ???
later
John
what else ???
later
John
Can't answer your question, but having just plugged about 100 random holes in my firewall (some factory, some not), I can sympathize. Once I peeled the crappy cardboard off my firewall, I could see daylight everywhere. Some of the factory holes appear to be punched with an air chisel, and are 1/2" diameter. After closing them up the cab is much quieter.
If you have a helper, a copper spoon behind the hole would help.
on
a helper would be nice.... tried the copper backing bar but almost impossible to hold in place with a magnet and then weld.... lots of walking around the door... lots... I didn't have a hundred.... but I probably blew in a hundred !!! I'd rather change diff fluid with bare hands and no rags ! but it's done now and behind me... one step closer to some paint puttin
j
j
on
Received 4,132 Likes
on
Sorry........Harbor Freight. I think it was rated at something like 50 lbs. and cost five dollars or less.
If interested you might check out the link
"Welding Tech"....When you don't have an extra hand. - THE H.A.M.B.
what else ???
later
John
what else ???
later
John
You can run the brake cable through the top left of the trans cover.
