Gas gauge not working
Well what was mentioned is everything it could be. You gotta start somewhere and narrow it down. Does it ever work? Does it read full or empty all of the time or somewhere else? Does it just sweep periodically back and forth? Do the other gauges work?
It's the biggest PITA but I'd start with checking the sender first since every time I have a fuel gauge problem that is where I end up eventually after trying everything else.
this also just happened to me last night. As the story goes: I've had my truck 2-3 days on the road now, last night with 3/8's of a tank I went to the gas station and threw in $40. It read 7/8's about. On my short commute back home it dropped and sat right at E. now this morning it doesn't even move up to E.....wha happened? Trouble is I'm still getting used to the gas mileage and judging it, needles to say I'm a lil nervous now. How does one go about fixing the possible solution mentioned earlier?
To check the fuel gauge - ground out the (orange wire?) connection from the gauge - if it reads "full," the gauge is functioning properly.
This link explains it better than I can.
Fuel Tank Sending Unit Tech - FORDification.com
Sweet, sounds like a good lead ya filthy beast lol.
Sc79 it could very well be the dash. I had it semi apart the other day replacing bulbs. I couldn't get that main electrical connection to the back of the cluster loose so I gave up trying until I was sure about how to go about it. I may have loosened something in the process. The fuel gauge did work after putting it back together though....for a day or two. The bottom right gauge (believe engine temp) hasn't worked at all in the two or so weeks I've owned it, maybe I can kill two birds with one rip apart/put together (best case scenario). I'll try that tonight and let yas know how it works out.
Agree on all the diagnostics. if all the other gauges work, the dash voltage regulator is probably OK. On mine (78 F250) the gauge wire can be disconnected just in front of the firewall for diagnostic test. My gauge didn't work and the sender was OK. I didn't really want to pull the cluster and send it out for repair (and wait) so an Autometer fuel gauge from Summit mounted to the left of the steering column fixed it.
