77 F-150 won't start...
1977 F-150 - 351M - Automatic tranny
I need some help before I blow it up!
I've had this truck for about 2 years now and it has been running fine. I decided to sell it since I'm moving soon. Guy comes to test drive it and it wouldn't start! It would crank but not fire. Checked for spark...no sparky sparky. I got a sweet package deal on a starter solenoid, voltage regulator, coil, and ignition module. Started changing them one at a time and trying to start in between. When I changed the ignition module, which was the last one I did, the truck fired right up! Ran great for 2 weeks then the same potential buyer dude came back and guess what?!?! Fired right up! He drove it 5 miles away and it died while he was turning around in a parking lot! I towed it home and figured maybe there was a bad wire frying the ignition module. Nope...checked every darn wire and they are all good. Tested the module and it is good. After hours of troubleshooting I said what the heck lets see if it starts. It did...but it wasn't firing all cylinders. Then a couple days later I tried to start it again and it wouldn't fire at all. I had a new distributor lying around so I threw it in just for s***s and giggles. Still won't start. I know this has been extremely long but I wanted to put as much info as I could. I'm at my wits end! Anyone have any ideas
8 volts on the RED wire coming from the truck, or the RED wire of the ignition module (assuming you have a later-model module with the swapped colors I described above)? If it was the RED wire coming from the truck, was the starter spinning, which would explain the sub-12 volt reading?
If every update from you requires more questions from me to clarify what you're actually working with, we're never going to get anywhere.
tylert1976
30
12-08-2012 01:07 PM
wantaford
13
04-02-2006 03:25 AM
Finnford
09-26-2005 09:38 AM
