Sticking front caliper
Hey everyone, I've been trying to figure out why my brakes are sticking but I've come up with nothing so far. A few months ago I had the front right caliper lock up due to internal rust. I replaced both front calipers, replaced all the brake fluid, and called it a day. I noticed though that the front right still sticks. After about a mile or so it starts to chirp and won't stop chirping, even at speed. I got fed up, warrantied the caliper, installed another new one, replaced all the rubber brake lines (thought it might be a collapsing line), flushed the brake fluid again and it still does the same damn thing.
Has anyone had this problem or know what it could be? I know it is something with the brakes; with both new calipers the wheel had resistance to turning when the truck was jacked up, but it spun freely with the caliper removed. I bled the brakes myself a few times, then even paid to get them professionally done. It's only the front right.
The truck is the one in my signature; 1997 F-250 HD, diesel 4x4. Thanks in advance for any help!
It doesn't pull to the right as far as I can tell, and now that I'm on my second new out of the box caliper, I have to think that it's something else. The shield isn't making contact with anything either. One thing I have noticed is that when I hit the brakes hard the steering wheel does turn left.
Makes me think that, along with not releasing, it might not be engaging either. Is there a valve that splits the front brake line pressures between left and right that could be sticking or is it equal pressure to both sides?
Maybe a wheel bearing? That rotor should be getting pretty hot if it's dragging. To the point you would smell it.
Pretty suspicious of the fact that it's happened with mostly all new parts.
So this has happened on THREE calipers at this point? I'd look further down the line, what about a clapped-out axle shaft u-joint?
Here's the D/S. Notice the T fitting.
And here's the P/S
Yes sir, not only are they new, but I lubed them.
This first time it happened the caliper actually had rusted up on the inside. After it happened I had both sides lathed and i put in all new wheel bearings and seals. And the weird part is that I don't really smell burning brakes. Then when I jack the truck up, that wheel is hard to turn. I know it is the caliper doing it because it spins just as easily as the other side when the calipers are removed. Technically, the first caliper failed, and its the 2 brand new (nothing from the junkyard) that haven't be functioning correctly. I'm thinking it might be a hydraulic problem but I'm not sure where to look for it.
Thanks again everyone for your continued help and ideas! Oh, and in case anyone's wondering if I'm complaining about a mouse fart, I can hear the squeaking clearly over the straight pipe diesel, even at 55 mph if my windows are down.
So I went off to see the wizard to ask about my problem (my buddy has 10W30 running through his veins) and he suggested the master cylinder. I'm going to see if it has separate or shared lines for the front brakes, if they're separate, that's my problem; new master cylinder for me! Stay tuned for more info! And again, thanks for your help!
Sorry didnt see the 4x4 part. Try lifting the front of the truck while its running then disconn ct the vaccum line from the booster then check the wheels and see if they freed up any. If they dont then try cracking the line going to the fronts coming off the master. If they get easy to spin then its the master. If it doesnt, start opening lines in succesion going from the master to the wheels until it releases. If none of them free up the wheels then its a mechanical bind.
Have you checked your tires ? You may have a bad tire broken belt .Try rotating your front tires side to side see if pull changes to other side .If that do't work try doing the same thing with the rear tires ..Also a bad front axle joint froze up or frozen ball joint could be causing your problem .You replaced the 2 brake calipers and rubber lines with new ones that didn't help plus I don't believe the Master cylinder would cause your problem >If it was the master cylinder causing a problem I would think both back or both front would be hanging Or locking up.
