Chip Chasers (prospective buyers)! Read this first!
#61
Just by the design....a straight thread is a running thread....a pipe thread is an interference fit and can be self sealing. Grab a 1/4-20 screw and 1/4-20 nut...put them together....where does the nut stop? At the head.
#62
The pressure transducer just screws into the back of the fuel bowl?
7 Bar (100 PSI) Fuel/oil Pressure Sender, 1/8 NPT. [AUBER-P207] - $55.63 : auberins.com, Temperature control solutions for home and industry
#65
Pikachu, you think we will need more than 6 feet of probe harness? They have a 13 ft option for $13 extra.
Could always use the shorter version, penetrate the firewall and then splice in normal wire...way cheaper....more work.
EGT Probe, Sealed Tip [TC-KEGTS] - $39.00 : auberins.com, Temperature control solutions for home and industry
#67
For the fuel pressure transducer, you'll need to find a bushing to convert the straight threads to match the 1/8" NPT pipe threads on the transducer. I don't remember what size the threads on the fuel bowl plug are, but maybe someone else can post it.
#68
#69
#70
#71
#74
I haven't quite decided yet. I'm leaning toward trying to find a lower dash panel from an F650 and mount it in that. If that doesn't pan out, I'm considering mounting in the spot on my dash where the ESOF control would be if I didn't have a manual transfer case. I haven't really made a firm decision yet. I'm one of those people who needs to consider all the options before I proceed. Sometimes, that's a bad thing . . .
#75
