Quick spring question... 6830LB = B code?
I have a 2003 F350, which i just noticed sags to the left pretty good (id guess from the 38gallon diesel tank over there), about an inch lower. Was already planning on putting X codes up front, so looks like i will replace the rears now too. My door code sticker says 6830LB, looks like that is for B codes? Does anyone have the P/N offhand? I just want to replace them with whatever came on them, and im guessing i will just re use the little block and overload spring? Thanks
I know, i know..backup lights arent equal height
If you order S-code springs from your dealer you will be good to go, this spring pack includes the overload. A quick Google search shows this as your part number: 3C3Z-5560-CA
Look at the very bottom of your sticker you'll see SPR, which indicates your spring code. Yours is "VS", for V-code fronts and S-code rears.
A set of air bags would fix your worries. $289 for the set, and you simply add pressure to the side you which to provide more support to. I have a set on the Excursion, you can check them out any time after next week!
Probably not, they wouldn't be worth anything. And from what I can tell they won't fit a Super Duty pickup.
Not really. You'd simply be adding the support that your sagging spring isn't providing anymore. Of course these air springs have different deflection rates than the leafs do, and therefore they will stiffen up as they compress in ways the leafs won't. I keep 20 PSI in the rears to keep the back level with the front, and the ride isn't much stiffer. The X-codes you are putting up front will stiffen things much more than some airbags if pressures are kept reasonable.
And if I'm keeping pressure to compensate for the lean will the ride be worse?
Is this the kit i would want?
Firestone Ride-Rite Kit 2550, Air Bag Kit Ford F-250, F-350 - TruckSpring.com
Either kit will serve you well though,
