1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
1961 Uni Fuse Block
Old 06-29-2013, 09:21 AM
TruBlu61's Avatar
TruBlu61
TruBlu61 is offline
1961 Uni Fuse Block
Hey all, new to the thread and definitely a novice when it comes to working on vehicles. I recently purchased a 61 f100 uni and am in the process of trying to straighten out the wiring. Appears that someone removed the fuse block from the light switch and started putting in some in line fuses instead. Any ideas on where I can find a replacement fuse block? Are there other early 60's ford trucks/cars that I could get one from? As I said I am a novice and any advice is greatly appreciated.
Old 06-29-2013, 11:56 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C2AZ-11A647-A .. Junction Block (fuse panel): 1960/63 F100/750 / 1960/63 Galaxie / 1960/64 Falcon/Comet / 1961/67 Econoline / 1962/64 Fairlane.
Old 06-29-2013, 06:51 PM
TruBlu61's Avatar
TruBlu61
TruBlu61 is offline
Bill you seem to be the grand-poo-bah of ford parts knowledge. Thanks for the insight and now its time to try and track one down.
Old 06-30-2013, 10:47 AM
TruBlu61's Avatar
TruBlu61
TruBlu61 is offline
Any recommendations on the best places to find NOS parts? I am compiling a list of misc parts and could also use some advice on where to find part numbers. I was hoping that the shop manual I purchased would have them but it doesn't seem to.
Old 06-30-2013, 12:19 PM
NumberDummy
1957/63 Ford Truck Parts Catalog available on a CD from hipoparts.com
Look up the part numbers, then type 'em into PartsVoice.com or rear counter.com, the two obsolete parts search websites available to the general public.
Old 07-08-2013, 08:51 PM
TruBlu61's Avatar
TruBlu61
TruBlu61 is offline
if it's not too much trouble do you have the ability to look up parts numbers for the following parts for me? I have found a number of these parts as reproductions but would prefer to use the sites you gave me to try and locate some NOS.
Drivers side door arm rest
Mirror extension arm (round mirror on door)
Dome light lense and housing
Turn signal lever
Radio antenna
Window crank ****
Inside door handle
Battery hold down clamps and hardware
Shifting lever **** (3 on the tree)
Glove box liner
Thanks in advance.
29abone
Electrical Systems/Wiring
01-20-2009 07:38 PM
Little Bro
07-19-2004 04:49 PM
ZombieSlayer
11-06-2003 10:29 PM
8NRay
09-07-2003 01:16 PM
Quick Reply: 1961 Uni Fuse Block
