Thinking of a 8" lift what you guys think?
I have a 2006 f-250 lariat and looking for the best lift that when i put on wheels and tires that im not going to get alot of road noise and i want something decent price and quality.
Pro Comp Suspension Part expk4036b - 8 inch Stage I Lift Kit with ES3000 Shocks
Think what you are doing with it first
If you are going muddin then great.If you use it for working then I would'nt go over a 4inch lift.I have a 4inch Pro Comp lift with 35's on it and if I did'nt have running boards on it, I would split my pants getting in. But useing for work it is perfect as it gives it a nice stance but its not to high to load and unload.
8" of lift will kill the fuel mileage, raise cain with steering and handling besides ruining a perfectly good truck. Go a max of 4" for both offroading uses and looks. You can run 35's and even 37's depending on rim choice. You'll have driveline issues requiring more money to resolve them.
So 4" and 6" which one would be best for gas milage and drive line issues? I'm having my truck programmed and tuned and also better exhaust and the egr delete kit what would the best looking lift do? Also I'm looking at a kit that including gas shocks and steering shock so what would you recommend?
Your lift should largely depend on what size tire you intend to install. Eight inches of lift with say 35' tires would look ridiculous. The tires you install are going to largely depend on what gear set you intend to run. 35's without a gear change is pushing it as far as performance goes.
There's more to it than just bolting on any old lift, and slapping on whatever size tire strikes your fancy.
IMO, the proper approach to lifting a truck is:
Step 1. Determine the tire size. This depends on how much "axle clearance" you want for the truck. If your truck came with 33" OEM tires, then going to 35" tires provides 1" of additional axle clearance, 37" tires provides 2" of additional axle clearance, 40" tires provides 3.5" of additional axle clearance, etc. The tire width determines the actual wheel size needed and impacts Step 2.
Step 2. Once tires are determined, then you can decide on how much lift is actually required. On your 2006 F250, 35" tires will require a minimum 2.5" leveling kit, 37" tires will require a minimum 4.5" - 6" lift kit, 40" tires will require a minimum 8"-10" lift kit. However, the Bushwacker cut-out fender flares can reduce the amount of required lift significantly. Smaller lift kits provide better handling due to a lower center of gravity, keep the truck a reasonable working heights, and are overall cheaper because fewer peripheral upgrades are needed.
Step 3. Depending on your OEM axle gears and engine, you can then determine if new axle gears are required.
This approach is a "functional" approach... the choice made in Step 1 impacts Step 2 and Step 3. The taller the tire size, the more expensive the overall lift becomes.
do 8 I did.. i have 355 60R20 nitto terra grapplers on moto metal wheels.. it has a great stance to it to.. i am 6ft tall and my rockers come up even with my hip.. without steps its a little much to get into.. BUT... I do get 14 mpg and have a 12" drop hitch when i pull.. it looks good and if you get the kit with everything drive spacers and link and end link drops then its all good... dont go cheap on a lift because you get what you pay for.. do 8... it looks good and feels good to be able to go offroad and have fun yet still pull and use it daily..(plus being one of the biggest on the road is nice)(the looks to.. lol) its your opinion but i love my 8... no regrets.. gear your front and rear ends though.. lol.. if you dont you will have drive line issues that you dont want to fix.$$$$$$$
I have mine apart or I would stand by it and get a pic but to give you an idea i'm around 6 foot and the hood is at my neck.Here is a 4'inch lift with 35 inch tires at a -5 on the rim off set so I can keep the rubber under the truck and the 35's are almost up to my waist.Notice tow hooks are almost to top of tire.I did not have to change my gear,brakelines or anyting special and the thing handles like a dream. I can take a corner like a Corvette and no body roll.
Well said! X2 and as a side note, a buddy of mine has a '12 F150, has 20" rims,,, a set of tires runs him $2500+ so start with your realistic budget and your tire size, it adds up quick!
