94 f150 no start
94 f150 no start
i did a search but couldnt' find what i was looking for. i have a 94 ford f150 5 speed with the 300 straigh 6. today it quit running and won't start back. it's not getting fuel or fire i'm not sure were to start. i've checked all the fuses and relays with a meter and they seem to be good. i also checked the fuel pump shutoff switch on the passenger side and it is good also. im not to bright when it comes to the newer electronic stuff so any help would be appreciated. i'm hopin it's a easy fix and not the ECM
Well if you have a good ground to the computer then I would say you have a bad computer.
Make sure the PCM power relay is closing when the key is turned on so that you have power to the computer.
One of the two small wires on the left is the computer ground in the photo below.
Computer ground point:
Island Time
01-25-2014 01:36 PM
skylonda
11-19-2013 02:10 PM
Trucklover_45
08-28-2012 09:03 AM
