Ha 11. The only reason I said 5:30 is because of we said 6 then the guys who get there later would get there at their normal time. if we say 5:30 then they might get there earlier I don't care either way, I'll just be happy of the bronco makes it.
sure, we can set 5:30 as a target, but it looks like i'll be working somewhere up north on saturday, so we'll have to see if i can make it down south at a reasonable hour - no guarantees on that yet
I'm not going to be able to make this one either. I am working on sat, and have plans for that evening. I'm hoping next months meet will work out. That's part of the reason I have been quiet about location and times.
The day is upon us now. My brakes are about half way done, I still need to put the adjuster on, add diff fluid, and probably grease a u joint or 2. They sound like they are squeaking a little. Add some motor oil and check a few other things and it should be good to go. If there is time and day light left I might hit the junk yard to look for parts, Josh needs doors, our van needs the mirror switch since that broke when we were trying to put it on. Busy day today.
i'm not likely to make it this time. i'm in the middle of doing the clutch on a BMW m3, and i'll probably keep me till fairly late tonight. have fun eating without me
No biggie, I got there just as Sean was leaving so I called him and he turned around and came back. We had a pizza and some sodas and relaxed a bit. It's been a stressful week.
