Well...your grandfather's taste in airplanes improved over the years...from a Skyhawk to a Debonair...not a bad upgrade!
The Skyhawk was his first and only plane he owned, which he sold shortly after getting his first company plane. Both company planes he had were were Bonanza A36s.
From the angle of the pic it looked like an F33A...both are straight tail Bonanzas. Company airplanes are the best kind!
You can use the stock 16"x 6" F-2 wheels because they are one piece. Finding a set might take some detective work, but they come available. Nice truck. Stu
Nothing on this end. The fact of an F-2/3 bed being wider than an F-1 bed the F-1 fenders are wider than F-2/3 fenders. Combining the F-2/3 bed with F-1 fenders pushes the wheel opening outward and makes the stock rear wheels look out of place. With wider custom wheels the appearance is helped. Since you want to keep a stock appearance, you could get some '90s era Dodge 3/4 ton steel wheels that are 17" x 7" (iirc) and fill up the wheel wells more. Stu
You're right Bob, bet it's the same one with 1/2 ton rear fenders. They look wider than F-2/3 fenders would be. Stu
That's the one I'm typing about.
Originally Posted by CLSSY56
You guys pegged it, that's the truck. It does have fiberglass rear fenders. What else do you know about the truck?
Nothing other than what Stu mentioned. It was mentioned here quite a few times years ago. I think it had been on eBay and CL a couple of times back around 2009. It was a nice looking truck but the rear fenders looked odd because they were F-1 fenders. They could be made to look correct with a like cutting and pasting to widen the wheel openings and narrow the width. If you're going to repaint it to match your grandfather's truck you might want to consider doing that.
Finding decent steel F-2, IMO, would be a lot more work. If he found steel fenders they'd probably need as much work or more. Fiberglass is pretty easy to work with, but very itchy. All it would take is some very careful measurements, a saber saw and a fiberglass repair kit.
Since he has the glass fenders I'd suggest he work with them unless he could find a decent set of steel fenders. I agree that's the best way to go.
