turbocharging an F100.
Title says it all, I have a 78 f100, 300ci, three on the tree, no power brakes, no power steering, 3800 lbs full of fuel and driver.
The plan is to fabricate an intake, install a throttle body (dodge Durango), fuel injectors (fi 300), turbo (7.3 powerstroke), intercooler and piping (Amazon), and to top it off with a megasquirt to run the show.
im still looking for a turbo, fuel pressure regulator, and fuel pump. any suggestions would be appreciated.
for background i thought the 7.3 powerstroke turbo would work because while the engine is around 50% larger in displacement the diesel maxes out at 3K while a 4.9 can spin to 5k theoretically, a roughly 60% difference.
(7.3/4.9)=1.48
(5000/3000)=1.66
good numbers!
So i'm thinking i move as much air as the diesel at redline (3000x7.3=21,900 litres) at a nifty (21,900litres /4.9 = 4469 rpm!!) so theoretically i move plenty of air to spin the turbo and I may be able to stay out of boost if i keep my foot out of it because the diesel starts building boost at 1600 rpm.(1600x7.3=11,680litres) vs (11,680/4.9=2,383 rpm). so im hoping for the low end grunt of the 300 to get me to 2,300 and then i should build boost quickly to somewhere between 12 - 16lbs.
as you may have noticed i don't take into account volumetric efficiency, cams, exhaust temps, fuel delivery or a host of other variables, this is just a rough estimate but it seems like it makes sense to me.
feel free to weigh in.
(7.3/4.9)=1.48
(5000/3000)=1.66
good numbers!
FORDSIX PERFORMANCE • View forum - Turbo, Supercharger, and Nitrous
That is a Forum that might interest you.
