Performance filter and chip questions
I seen for bang for your buck 6637 air filter is the best route. Not the best eye candy though haha. Is there any other filter setups people like ? I found a white pipe with k&n stile filter for around 175$ but from what I been reading the k&n let in sand and dirt. Any other filters worth lookin at?
I was reading also about performance chips on the sticky. I want a ts stile chip with a 6 position "switch on the fly" ****. I read the ts performance chip is no good because their just preloaded tunes ? It seemed great for only250$. I don't want a expensive screen tuner/ stile chip. I only want the chip you add to the PCM . With the **** to select
Is it correct since my truck is all stock injectors I won't see much gain? I have turbo back exhaust on its way and after that I'm going to buy an intake then hopefully a chip
You guys are the experts, so I trust everyone's experience
TS style chips are the best ones for our trucks, but you do want custom tunes. I wouldn't worry about a chip until you get some other supporting mods like injectors, HPOP, etc. You want gauges before anything though. You will need the gauges when you start modding the engine.
Right, I forgot to add gauges are coming in spring, Exhaust temp pyro boost
I also did see the 6637 cover stainlessstroker, that does look nice
Coming from my 96 f150 to the stock powerstroke is a change for me. The 5.0 really hauled out. I thought turbo back exhaust, intake and chip would wake up this truck
Isn't there any tuner people selling ts stile chips on the forum here?
This is one I saw on eBay
http://www.ebay.com/itm/TS-Performance-6-Position-Switch-Chip-94-5-03-Powerstroke-7-3L-UP-to-140HP-/271146394970?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2195a55a&vxp=mtr
Did you read this?
https://www.ford-trucks.com/forums/1...rogrammer.html
Good info there with some links
Did you read this?
Yes I read that first, I was ready to buy the ts 6 position chip with "canned" tune for $250 until I read this.
I want to know whats the best reasonably priced chip for my truck. The only thing ill have done to my truck is the intake and turbo back exhaust
I believe PHP is still the best price for TS chips. However, you can buy the canned tunes and have them re burned for around 350 total. Each tuner is going to have a pretty loyal following on here. You can't go wrong with any of the big name guys.
Ok I'll go threw the chip guys on the mods post sticky
