Lighting upgrades?
Here is the harness that I would use for my truck and looks like this one might work for your year in the pic - Truck Parts and Truck Accessories
How is the light output with those above?
It's as easy as can be, comes with plugs that go to your headlights. So you don't need to worry about making custom connections there with wire taps. I haven't used this (I made my own before I knew this existed) but it's damn easy to install.
I do know what it does: instead of getting it's power from the headlight switch that also POWERS ALL OTHER LIGHTS like dash and marker, this will pull all the power the headlights need directly from the battery. The result is the headlights have more power and are brighter than before, they're as bright as the bulb is rated for out of the package.
on
I did relays on both of my trucks. On the dump truck, to see homw much differnce it would make, I ran a wire from B+ and backprobed the connecter at the light. When I hooked it up and unhooked it, I could see a noticeable change in brightness. IIRC, I checked with a voltmeter and was losing about 2 volts between the battery and headlight. I highly reccomend it. It also takes the load off of the headlight switch which is prone to melting.
KC lights are for off-road use ONLY. Using them on the highway can blind other drivers and/or get you a fat ticket from a LEO...
I thought up to 150 watts was still technically street legal. I may be wrong. I know they don't bother you around here over that kind of thing but I would like to keep it legal.
It's not always wattage, etc...(Which produces heat and WILL melt down the plastic housings)...Aim, projection and bulb color all play a part in effective lighting.
#30
