2002 F-150 5.4 P0174 Too Lean
So the past few weeks my truck has been sputtering a lot. It seems to do it more so in low RPMS but when I lay on the throttle I didn't really notice it. I haven't had time to look into the issue but yesterday the issue got drastically worse and the CEL finally came on. Registered P0174 as well as a number of other codes including misfires on 7 of the 8 cylinders. So far I have replaced the fuel filter. Spark plugs are only a few months old. I didnt think it would make sense for all of the coil packs to go out at once so I was thinking either a fuel issue or vacuum leak. Why would it only spit out P0174 (Banks 2) and not show P0171 (Banks 1) along with it? Fuel pump? Vacuum leak? What do you guys think? Where should I start? Thanks!
