Trucks been puking for about 6 months so I'm thinking its head gaskets but I wanted to delete the EGR first to rule that out and when I took the vertical EGR cooler off my EGR valve was full of black water/coolant. Any thoughts? Is this a symptom of blown gaskets?
Changed the coolant cap a couple of times and the dealer confirmed combustion gases in coolant. Haven't heard about hyperextended thermostats. Is this a possible issue?
That's what I have been planning on doing for awhile now. Just want to make sure it's not anything else before I spend all that money to pull the cab and do gaskets. Also when I am just idling my ac starts blowing warm air and my oil temp has been getting real high when towing up to around 230 EOT.
? If my EOT/ECT delta is always within 6 degrees or so my oil cooler should be fine right?
What do you think is the problem with my cooling system from not being maintained?
Should I check for hyperextended thermostats first or just change head gaskets and add some arp studs? What do you think? Can Hyperextended thermostats cause puking issues?
Yes, I would tend to think that could be some of the causing, however you said you had exhaust gas in your coolant. That won't come from thermostats.
It is easy enough to pull the t stats and have a look though.
Just pulled 2 codes
PO528 fan speed sensor circuit no signal
PO480 fan 1 control circuit
And when my oil and coolant temp was high the other day while towing my fan never came on
