Regearing question
Regearing question
Im going to need new tires soon. I was Looking at the Goodyear Duratracs in 325/65/18. Right now I have 4:10 gears in my truck and wanted to know if I would have to regear? I know that the milage will suffer but im worried about burning up the tranny if I dont have the right gearing.
My Specs:
2005 F250 4x4 lifted 4"
V10 Engine
Torqshift Tranny
4:10 gears
Thanks for your help.
My Specs:
V10 Engine
Torqshift Tranny
4:10 gears
325/65/18s are going to be between 34" and 35", they're not exactly "large" tires by any stretch. A lot of trucks come from the factory with 275/65/20s, which are only about a half inch smaller than what you're looking at, and some came with 3.73s behind the gassers, so my recommendation would be to put them on first and worry about gearing later, once you decide if you like how the truck still pulls. If you don't have one, get a trans temp gauge or a Scangauge to replace the dash board idiot stick, and you'll be G2G.
35s, 4,10s and a V10 won't burn up the tranny, unless you really leave common sense behind in the driveway in the morning
Thanks again TexasTech
Thanks for all the replys....What I would like to do someday is to install some kind of locker in the rear diff....I have the limited slip and only one tires spins when im in the snow or wet grass...Now I hear that I should of applied the brakes a bit and then they both will spin? resulting in me getting traction. Also I am using Royal Purple gear oil in my both of my diffs...It has the limited slip additive in it...I wounder if theres to much additive in the oil??
....Gage
....Gage
rdmobile
1999 to 2016 Super Duty
11-20-2013 05:05 PM
mrdoughnut
01-04-2012 07:38 PM
