Check Suspension Light
Hello all. I am new here and was hoping someone could help me out. I have a 2000 EB, the check suspension light came on in my truck and I no longer hear my compressor turn on. Obviously I suspect the compressor but was wondering if there could be someother problem. I checked the fuses both inside and out and they are fine. I didn't know if there was a switch or sensor that may go bad and I could replace that instead of taking it to the dealer.
If I do take it to the dealer, and it is the compressor, how much should that cost? Can I buy a used or remanufactured compressor?
Thanks for any help you may give.
I have a 97 XLT that has 4 corner leveling and my compressor went once right after the warranty. I took it to the dealer (I'm in Canada) and explained to them that the warranty just expired few weeks and few hundred km's ago and they did a 80-10-10 for me. Meaning that Ford will pay 80% of the cost, 10% covered by the dealer and 10% by me. The total cost was quite large and I ended up paying around $2-300. It has been a few years now and I am not sure how much it cost now. Good luck and maybe you can get your local garage to locate a used one in the junk yard, but no guarantees...
Don't risk it ! When the compressor is not pumping the airbags, (well, in my case, the left rear broke while driving to the delership) and it costs another $600 (Cdn), which is about US$400. Not to mention the whole truck is lowered like you have your compressor turned off, but the ride is bouncy because the only thing that keeps the truck up is the shocks and they are not designed to take the load (even when the truck is empty). Better get it fixed.
Thanks for all your input. I took it to a buddy of mine who fixes police crusiers for the county. He went under my passenger side dash and flip a switch and presto, the pump came on. I did not know the air suspension had an on/off switch. Apparently my wife must have kick it off accidently. Talk about a relief. Thanks again everyone. David
M.Summers
1997-2006 Expedition & Navigator
12-26-2014 10:51 AM
ballfan95
1997 - 2003 F150
06-12-2011 04:43 PM
cesario6868
01-24-2011 09:26 PM
02, 1997, 1999, 2000, check, chk, coming, expedition, ford, light, lite, shocks, strutmaster, susp, suspension, suspention
