1960 Super Duty Crew Cab build thread
Old 07-13-2016, 08:40 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
Went to Modesto CA and got a complete set of vintage Budd 22.5 tubeless rims with the old 8x10 bolt pattern off a 57 F750 fire truck.
Budd wheel
Budd 70420
I have two of these on the front currently which are slightly wider, but otherwise identical:
Budd 69640
  #227
Old 07-17-2016, 04:58 PM
78_f800crewcab4x4
22.5 Budd rims dismounted and soon to be off to the powdercoater.
Also acquired an extension section for the bed:
Back to the RH cab mount:
The following users liked this post:
  #228
Old 07-17-2016, 05:42 PM
78_f800crewcab4x4
Weld-through primer. Tape over weld areas.
1957 F750 cab support structure re-assembled.
  #229
Old 07-17-2016, 09:06 PM
54Hydro's Avatar
54Hydro
54Hydro is offline
I've been trying to piece together a few sets of those vintage 22.5s for awhile myself for some 40s vintage trucks in the family. At least yours were 8 lug, 6 lugs are really difficult to find.
  #230
Old 07-17-2016, 10:22 PM
78_f800crewcab4x4
The 8 on 10 pattern Ford-only tubeless was only available from 1956-1963 on a small portion of f750-f800 trucks. The six lug is rarer than that?
  #231
Old 07-17-2016, 10:40 PM
54Hydro's Avatar
54Hydro
54Hydro is offline
I have managed to find 5 through farm auctions and know where a sixth is at a bargain store (we don't have pawn shops). My family has three non Ford 6 lug trucks (so we need 18 total eventually) that we would like to get off of the 20s as some of them are the RH5* Firestone widow-makers.
  #232
Old 07-18-2016, 07:24 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Six lug? I know of a couple yards around here that have quite a few.
It's the five and eight lug wheels that are a bit uncommon.
  #233
Old 07-25-2016, 06:07 PM
78_f800crewcab4x4
floor pan/cab brace assembly:
Note that the battery box opening needs to be opened up on this floor:
  #234
Old 08-06-2016, 06:15 PM
78_f800crewcab4x4
Original 1957 ford truck radio antenna in factory location:
Welding Cab mount/floor pan joint.
  #235
Old 08-09-2016, 10:39 PM
78_f800crewcab4x4
Floor pan welded up with patches. Unfinished.
This stamped brace panel goes over the top. Unfinished.
  #236
Old 08-10-2016, 09:58 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Is your hood scoop in the original position? I recently found one I want to put on my 59 and I thought it would mount more foreward
  #237
Old 08-11-2016, 12:36 AM
78_f800crewcab4x4
Yes it's in original location. A 58-60 pickup hood will be different. Simply mount it directly above the air cleaner so that you can make it functional.
  #238
Old 08-22-2016, 08:28 PM
78_f800crewcab4x4
Scored two sets of ventshades.
  #239
Old 09-03-2016, 04:47 PM
78_f800crewcab4x4
Ford Truck LOW AIR lamp for air brakes. Will illuminate red "BRAKE" when air falls below safe levels. Operates with the original buzzer.
I can now be warned when the future stereo is blasting metal and I cannot hear the buzzer.
This fills the choke or throttle cable location.
  #240
Old 09-03-2016, 05:23 PM
78_f800crewcab4x4
Pulled out the original speaker.
The speaker has the exact same mesh as the hood scoop.
I will probably just re-install it for someone in the future to play with. Putting the grille in the powder coat pile.
Quick Reply: 1960 Super Duty Crew Cab build thread
