'89 F-250 w/ 302 400hp
on
The reason people are discouraging you from building a high horsepower 302 is because in a 5000-6000lb truck the usefull powerband is gonna be 3000-6000rpm. With the right axle gearing it'll get the job done but it's not gonna get anything that could be confused with gas milage. There is no way to get big low rpm torque from this motor there's just not enough displacement, so a more realistic target for typical truck use would be 300hp from a 351 or 351 based stroker. That is doable on a budget because it doesn't require an expensive aftermarket topend, just some GT40s, a cam, longtube headers, a fresh bottom end, and you can keep the factory EFI and overdrive transmission if so equipped so despite the larger displacement it will still get reasonable fuel milage.
Conanski, I agree. In our heavy trucks the torque that a 351 and set up you describe is. For me the way I would go.
slaney30
13
09-21-2012 08:16 AM
andrewk
09-22-2009 09:11 PM
idfliers
02-11-2004 08:55 AM
ucmeflyby
10-10-2003 05:46 PM
bigredf150
09-28-2000 09:53 PM
