1955 F250 (Emma) Build Thread
Old 03-16-2013, 07:29 PM
Rocketman55's Avatar
Rocketman55
Rocketman55 is offline
Cut the bed from the truck today. Fun times with a wire brush ahead.
Old 03-16-2013, 07:33 PM
bhd6th's Avatar
bhd6th
bhd6th is offline
rust seems pretty tame!
Old 03-16-2013, 07:40 PM
Rocketman55
yeah, not bad at all. It was originally a cow feed truck in east Nevada and the PO said the bed was totally hammered from the salt blocks they would carry. Did not seem to work its way to the frame at all. Wire wheel, pressure wash, Loctite Extend and a coat of paint. Then a temporary wood flatbed until I decide what I want to do. Notice the shortened frame...the PO converted it to a short bed
Old 03-16-2013, 07:43 PM
bhd6th's Avatar
bhd6th
bhd6th is offline
thats a shame, I do love sort of hd look of the 250s with that longer bed.
Rocketman55
And the PO had this great idea for a custom dual exhaust
Old 03-16-2013, 07:48 PM
bhd6th's Avatar
bhd6th
bhd6th is offline
bwahahaha well hey, whatever works right? Cant say I haven't done some goofy hack jobs like that myself! in the end though taking the time does pay out
Old 03-19-2013, 03:53 PM
Coyote13's Avatar
Coyote13
Coyote13 is offline
Well that IS custom!
Old 04-26-2013, 09:15 PM
Rocketman55
Ok, so the frame from under the bed is cleaned, rust inhibited and painted. Ready to start fabricating the temp flatbed.
Old 04-28-2013, 07:30 PM
Rocketman55
Spent the weekend fighting the ole gal but the engine is out. No shortage of things to clean refurbish.
Old 07-21-2013, 10:12 AM
Rocketman55
Certainly not progressing as fast as I'd like but I'm about ready to start putting her back together. New front brake lines are bent and ready for fit check today. Engine cleaning/re-painting still in progress.
Old 08-16-2013, 12:59 PM
Rocketman55
New brake lines bent and flared. Front assemblies cleaned up nicely.
Old 08-16-2013, 01:20 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Rocketman,
It's looking good over there in Utah! You'll feel a lot better once it starts going back together. I noticed some real live headers in your pic gallery - what's your plan for the engine?
Ben in Austin
1950 F1
  #28
Old 08-16-2013, 01:28 PM
Rocketman55
239 Y block seemed to be running good when I pulled it so only refurbishment. Engine cleaning is making good progress. Exhaust manifolds have been sand blasted and POR15 applied/cured. Cross over is on back order from Sac Ford. All other engine parts cleaned/primed and painted. A bit more cleaning on the block itself, paint (yellow) then its time to put back on the frame with new motor mounts (The old rear mounts looked like they had been in a fire with the rubber just a gooey mess). I hope to have it on the road later in the fall.
  #29
Old 08-16-2013, 01:48 PM
Rocketman55
and just for fun here is the condition of the front assemblies as they were removed.
  #30
ben73058's Avatar
ben73058
ben73058 is offline
Hey Rocketman,
My hats off to you for taking apart a truck that was running & fixing & upgrading everything! It took almost 2 years to get our's back into operation with a lot of help. I like your engine plan - will be beautiful when you are done!
Ben in Austin
1950 F1
Quick Reply: 1955 F250 (Emma) Build Thread
