2000 Ford Explorer - Violent Shaking in steering after hitting bump or 60+ mph
Old 02-27-2013, 07:36 PM
Blake Phipps's Avatar
Blake Phipps
Blake Phipps is offline
I just had vehicle inspected and replaced the wheel hub assemblies on the front Left and Right wheels in order to pass. Now while driving strong shaking occurs occasionally when over 60+ mph or at any time after a hit a bump in the road. have to slow down below 30 for it to stop.
Old 02-27-2013, 07:47 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,638 Likes on 1,336 Posts
Death wobble....
My '98 did this and it turned out to be the combination of poor wheel balance, worn ball joints and too high tire pressure. Pulled the tire pressure down to and the problem "went away". You should be so lucky.
Ball joints, tie rod ends, the rack and it's mount are suspects, along with bent wheels and fubar'd tires.
Everything needs a close look.
Old 02-27-2013, 08:41 PM
Flash635's Avatar
Flash635
Flash635 is offline
What 85e150six4mtod said.
But I would think if too high tyre pressure was causing a problem then you might have belt separation which would also cause a wobble.
That and loose wheel nuts.
Try moving a back wheel up to the front to see if that stops the wobble.
Old 02-27-2013, 08:43 PM
Flash635's Avatar
Flash635
Flash635 is offline
@85e150six4mtod
What do you call too high tyre pressure?
We don't want a repeat of the exploder days.
I use 36 to 38 psi in 235/75/15s and about 34 - 36 in 255/70/16s.
Old 02-27-2013, 11:22 PM
85e150's Avatar
85e150
85e150 is offline
I had one at 39. Try 30.
Ford spec'd 26, and owners didn't check them, letting many drop to 15!
30 (or even 26) is fine as long as you maintain it and don't let it drop off.
Old 02-28-2013, 01:00 AM
Flash635's Avatar
Flash635
Flash635 is offline
26 psi is too low regardless of what Ford says.
When I bought my first Explorer it had 28 in the tyres and it bounced around badly. It also had the original shocks though.
I'd use no less than 32.
Old 02-28-2013, 04:12 PM
Blake Phipps
Thanks for the input. Im getting it back up on the lift tonight to try and address what ever issue is causing this...
Brian92390
1999 to 2016 Super Duty
10-20-2014 04:29 PM
cory5517
08-05-2013 04:01 PM
Irish816
01-10-2012 12:27 PM
Bunggo
1997 - 2003 F150
17
04-20-2007 12:46 PM
Quick Reply: 2000 Ford Explorer - Violent Shaking in steering after hitting bump or 60+ mph
