Im removing my gp, first theres oil sitting on top of each one. do i remove the oil first? second, Iv read that the piston on cylinder one has to be on tdc? or can i just remove then all very carefully.
i would just take them all out at once, dont worry about tdc, i wiped up some of the oil but what i did....with them all out, i disconnected the CPS and cranked it over to blow oil out. are you replacing the valve covers, harness, and relay as well?
yup when i was getting ready for mine, some one had to redo theirs cause oil got in the cylinder and locked it up. it might blow a mist, might not. i felt better knowing there was no oil puddles in side.
just checked the time stamp, you should be about done. hope all went well.
Did you also replace the glow plug relay? I just did gp's and the relay and have a buzzing now that I didnt before. I assume it is the relay because it stops when the relay shuts off.
mine buzzed too. i just (literally just finished)put two new harness side valve cover connectors and now it has a solid click when i put key to on. id check those valve cover connectors again
