88 4.9 2wd worth switching to the saginaw pump?
While looking through the upullit I spotted an e series van with the metal saginaw pump and bracket on it.
The factory pump, or factory type replacement, not sure which, its doing fine on my truck outside of a small leak where the line was rubbing.
Is it worth the effort and expense to switch out the pumps on a stock 2wd?
If so, does anybody know for sure which lines I need to make the switch?
Thank you.
Thank you.
fmc400
41
09-29-2023 09:46 AM
jayro88
05-06-2017 07:31 PM
SoCalAngler
33
08-14-2014 10:04 PM
roscoe14eb
10-09-2011 10:54 PM
