EGT/Fuel Pressure Gauge Recommendations?
I currently have an Autometer ford factory match EGT gauge and it stopped working today (stuck at 500 degrees even when unplugged). I know it's the gauge itself since I borrowed the gauge from my father's truck and it worked normally, so it's not a wiring or thermocoupler issue.
I am going to call Autometer tomorrow about the gauge and see if they can do anything but I'm not expecting much since it is over the warranty.
What gauges would you guys recommend? I am also in the market for a fuel pressure gauge as well.
I have both Autometer and Isspro EV2 gauges.
I went with the factory matched Autometer gauges on the A-piller Pod.
EGT, Boost & Trans Temp gauges.
Last fall when I installed my gauges Autometer didn't make an electronic fuel gauge. Not sure if they do now. So I went with the Isspro EV2 gauges for my under dash mount pod. Fuel Pressure, Oil Temp and coolant temp gauges.
I installed the R17044 - EV2 Electronic Fuel Pressure Gauges 0-100.
Both brands work great. If you are adding other gauges I would recommend the Coolant Temp gauge.
genscripter
03-23-2018 12:55 PM
