7.3 Rebuild...the beginning!
Rebuilding my 2001 7.3 out of my Excursion. May not be my smartest decision since nothing major was wrong with the motor, but with 400k miles and wanting to do some performance upgrades anyway the timing was right. What convinced me was confirming I had the infamous powdered metal connecting rods, the chewed up turbo, and a host of little things that unto themselves were no big deal, but wanting to add more HP to this motor I knew that the only safe bet was to get rid of the PMR's and do the project right. After all, deciding not to buy new again allows me to put less money (than a new truck) into this rig and have what I want. This all started when I found the air filter from the intake off the inlet tube in my airbox resulting in the compressor wheel getting hammered. A very expensive lesson, and one I am very unhappy with the manufacture over, but thats another story.
So here I am at step one, breaking it down to pull the motor tomorrow.
I was very pleased to see that the coolant filter system and the HD ELC was doing it's job. Clean, and no cavitation!
Stock injectors, soon to be replaced, along with a list of other upgrades. The block and heads go to the machine shop on Monday, and that will be about 30 days as it's a busy shop. I'll report back on the quality off work and hold of naming until I see there work first hand.
If there is interest I'll keep this thread updated as time permitts.
Looking at the stem it looks to me like a worn valve guide. What is it Pop's?
The reason for my question:
After considering the turbo-caused back-pressure, I wonder if oil getting past the guide seals wouldn't have a tough time getting through the guide.
Of course, if that were to be the case, how would the guides get lubed at all?
As I said, I dunno'.
I hope you'll let us all know as this thread progresses and you have been able to measure clearances.
Pop
Well, not proud to admit it but apparently you have to continiously check to make sure your intake filter stays attached to the intake tube. With the unit I have when I though it was good to go, I was apparently wrong, and on more than one occasion. An expensive and embarrasing lesson, but maybe someone can benefit from my mistake(s). Here is the photo showing debris that came in the intake when the filter fell off, and the damaged compresor wheel on my GTP38R. Followed by the next photo of it cleaned up and ready to go with the new WW2 compressor wheel. Now all I need is a motor.
Yep, and the embarrasing part was I knew I was having a problem with the filter seperating and during a 3-month period when I was working 14-16 hours a day 7 days a week on a major design project for 25 sites I totally spaced out checking, and when I did think of it I was too tired. Now I get to pay the price. Tough reminder lesson Steve.
