HP oil rail test gauge
I do have an Isspro EV2 Hpop guage in the dash already that gets it data from the ICP sensor/PCM , but as you know there are certain failure instances where the PCM will not be telling the truth.
Built me one yesterday, for fuel and oil psi. Waiting for the #5orb to come in, to test hpop ports...
5000 PSI Filled Gauge
200 PSI Filled Gauge
Using a grease gun hose, rated at 3000psi, for the fuel/oil psi, dont think i wanna try it testing hpop..just in case. gonna have the company i found the fittings for, make a hose quick for me....
18" Flexible Grease Hose
Oh yeah, I forgot that the HPOP gauges used the value from the ICP sensor, spliced right into the pigtail right? I just had it in my head they came with a new sender.
Although I guess you could purchase another ICP and pigtail and tie the gauge into that one to get a 2nd reference.
Other than that the kit does seem convenient in the fact that it keeps from having to find everything if you didn't have a hydraulic supply near you.
timhugg
11-07-2009 09:42 AM
fordpower69
10-04-2008 06:14 PM
nelstone74
01-14-2008 08:33 PM
