46 Ford Truck
Old 07-19-2016, 09:06 PM
Joe777's Avatar
Joe777
Joe777 is offline
Originally Posted by 44jailbar
Remember there are two positions the radiator can be bolted into depending on engine type, V8 or inline 6. This means there were two different width shrouds available and I think there was also a rubber gasket of sorts also between the shroud and radiator.
44jailbar
Good info and now you have me wondering if I have the radiator set in the correct position. I'll have to take another look at it.
  #197
Old 07-19-2016, 10:58 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
On my tonner panel I didn't realize the difference in radiator placement until everything was hooked up. The front clip came from a 6 cyl truck and I have a V8. Well it still runs cool and I have a lot more room to mess with the distributor if needed. I don't have a fan shroud and I tend to run empty and live in a moderate climate so I get away with this placement.
  #198
Old 07-20-2016, 05:37 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
It isn't just the radfiator placement. Parts are different. I can't remember the name of that top piece in front but the 6 had a shorter one than the V8, maybe other things too
  #199
Old 07-20-2016, 12:13 PM
Joe777's Avatar
Joe777
Joe777 is offline
Just got back from looking over my configuration. The radiator/support bracket are set in the aft most set of holes in the crossmember and the four (2 each side) forward inner fender bolts go thru the aft set of holes in the fender brackets. The upper radiator grille air deflector is the deeper(longer) type. So I guess this is the correct configuration for the V8 trucks????
I know for sure that if I ever have to do some serious engine work in the future, I'm going to remove the front clip as a unit and not in pieces. There are lots of bolts in tight places on that front end!!!
  #200
Old 08-14-2016, 07:58 AM
Joe777's Avatar
Joe777
Joe777 is offline
Got my turn signals mounted and wired up. We ran a ground wire to each light and are really pleased with how bright they are.
  #201
Old 08-22-2016, 05:47 AM
bernette's Avatar
bernette
bernette is offline
looking good!
  #202
Old 08-22-2016, 10:19 AM
GB SISSON's Avatar
GB SISSON
Yes, they look really bright! I would expect nothing less in your amazing restoration.
  #203
Old 09-09-2016, 10:13 PM
Joe777's Avatar
Joe777
Joe777 is offline
Today I installed some fog light on the truck. Still need to get them wired up. They are pretty bright and I thought they would be good daytime running lights.
  #204
Old 09-10-2016, 05:43 AM
bernette's Avatar
bernette
bernette is offline
nice real nice!!!
  #205
Old 09-11-2016, 08:16 PM
Joe777's Avatar
Joe777
Joe777 is offline
The weather here today was just beautiful and I just couldn't resist pulling the truck out of the garage. Actually I couldn't resist taking it around the block a few times. This is the first time the truck has moved, under its own power, in 20 years. The purr of the engine, the whine from the tranny, and that old truck smell really brought back some memories. I still need to install the door glass, door handles, and interior panels but she is getting there.
  #206
Old 09-11-2016, 08:28 PM
newold46's Avatar
newold46
newold46 is offline
I think I've said this before, but damn what a pretty truck!
  #207
Old 09-11-2016, 09:56 PM
Nighttrain67's Avatar
Nighttrain67
Nighttrain67 is offline
You're giving me hope! Really like those fog lights
  #208
Old 09-12-2016, 05:40 AM
bernette's Avatar
bernette
bernette is offline
lucky guy! looking real good!
  #209
Old 09-12-2016, 06:27 AM
Joe777's Avatar
Joe777
Joe777 is offline
While we had the truck out in the daylight, we noticed that the taillights are so dim you barely notice their on and the break lights are only marginally better. Already painted the inside of the light silver so maybe look for a brighter bulb??
  #210
Old 09-12-2016, 08:11 AM
FireEngineMike's Avatar
FireEngineMike
FireEngineMike is offline
Check your grounding. All that shiny new paint is not conducive to electron flow. BTW, you get brighter light using white paint instead of silver on the inside of the housing.
Quick Reply: 46 Ford Truck
