pitman arms
pitman arms
Here's the scoop...it's a 67 2wd frame and most body parts, but I used a 72 cab with 72 steering column (automatic). I also used the 72 steering gear but the pitman arms are different. I don't have any preference as to stock or aftermarket...just as long as i can get the correct pitman arm to keep linkage from binding. I've tried Ford but am having trouble finding what will interchange between years. Thought about using someone who makes custom parts. I can give them the dimensions on the pitman arm i would need...just don't know who to contact.
