Great news. What mods need doing for the increase to 4495kg? And to 5000kg?
An engineer in S.A. has agreed to increase mine to 4950kg as long as I put upgraded shockies on all 'round.
Another engineer in Vic is still looking into it, but reckons either new shockies or rear springs plus maybe a new sway bar.
G'day Scott,
I'm guessin' you've been talkin' to the same mob I used for my GVM Uprade to 5,000kg and recommended you contact them?
The 'Ginger' (Gingerbeer (Engineer)) had no hesitation for my upgrade as soon as he inspected the truck. He noted the upgraded heavy duty ARB Springs front and rear, the OME Nitro Shocks. He wasn't over concerned about me having the bigger 305 75R 16 Load range 'E' tyres as he would have been happy with the stock size of 265 75R 16 'E' and noted that on the compliance plate 'Tyres - No Change'. The only thing noted on my upgrade compliance plate is 'Upgraded Suspension' for a 5,000kg GVM.
I only went in to get an upgrade to 4,495kg, but on inspection said he would give me 5,000kg if I wanted so I did .
I already had a full truck licence, so the missus went and did a Light Ridged Truck Licence test without any dramas.
The GVM upgrade in no way changes the towing capacity of 4,500kg or the GCM of 9,072kg. This is because the Towing capability of a vehicle is mainly calculated on the mechanics of the drive chain, chassis and the braking capacity.
$580 here in vic fark im not moving too QLD then rip off ******
My Vic rego will increase from $600 to $1200 when the GVM goes above 4.5t. Good news is that my insurers don't care about the change - I was sure they would be next in line for a handout..
when he finishes he's freakin fences That should be around 2015
u heard of the great wall of china. well its actually in victoria..larf.
40000 comedians out of work and you still wunna be 1 sir larf-a-lot
u cunny funt,lyn said pull ya finger out and except her as a friend on facebook or look out she said ..... ur in the **** with my mrs larf at that mahahahahah
ah u crack me up bro. I only joined f/book so I could c the specials Clay throws up. I have logged on to the useless thing about twice since I joined. Tell Lyn I will log on again just for her but dont expect much response.
