2001 V10 TPS Low Input Code
I have removed the throttle position sensor and it appears to be a spring loaded potentiometer. I have tried re-installing same working sensor and cannot seem to get it right or i broke the damn thing! Is there a trick? This is the one with the three pronged connector with the two tabs where it links up to the shaft end on the throttle shaft... I have searched and can't seem to find the answer to this one. Thanks ahead for any help!!
Truck:
2001 F250 V10 4SPD Auto Super Duty Lariat Crew Cab STD Bed 2X4
Truck:
I had other issues that I had taken care of... Fuel rail low pressure. I read a number of posts and replaced the 5 year old fuel pump. filter was changed TPS changed out and runs great again! One note, the tranny shifted hard up through the gears when the TPS was giving the low input... Thanks!
ResJudicata
1997-2006 Expedition & Navigator
01-07-2016 09:52 AM
kenneBF250V10
Modular V10 (6.8l)
01-31-2005 07:18 AM
