What is Rev-X and why does my 6.0 need it?
I used it to help with the stiction I was getting at start-up. Supposed to help turbo spool up but I did not really notice it. Check out their website too...
About | REV-X Products, Inc.
rev-x is a product made for a profit, claiming many benefits.
the main reason you should be using it is so they can make money.
it's biggest claim to fame is reduction of stiction.
my thought is that if i'm running 5W-40 rotella T6,
i'm dumping $80 into the crankcase ever 5,000 miles,
and that is quite enough. the cost benefit ratio would
be far exceeded for any advantage offered by this product,
real or imagined.
in my not so humble opinion, that is.
My actual experience:
1) I have the classic cold stiction issue. The truck runs really rough (it misses, stumbles and sounds wrong) from 1800-2100 RPM while the Engine and Coolant temps are below 100. At which point it slowly gets better and is gone around 150 degrees.
Solutions
1) Synthetic Oil 5W-40. The largest improvement was gained by this change, that was 30k ago. I prefer the Mobil 1.
2) 25k ago I tried the hot-shot product. No noticeable change
3) 5k ago I tried the Rev-X product, 2 bottle treatment. It improved the issue, didn't solve it, but it was better. The stumble was still there but the amount of stumble was less.
4) New oil change last week, I really think the Rev-X product effects are gone. The stumble seems to be back as usual.
In my case, I just let the truck idle for 3-5 minutes before driving and by the time I get to the highway and need the higher RPM's the temps are up and the problem is gone.
Eventually the injectors will have to be addressed, but a little idle time in cold weather has solved the problem for the last 30k.
Solutions
Solutions
.... I tried the hot-shot product. No noticeable change
.... It improved the issue, didn't solve it, but it was better. The stumble was still there but the amount of stumble was less.
New oil change ....
Solutions
New oil change ....
You can make your own choice on addadtives. I am not saying that it didn't help at all; maybe it did, maybe it didn't. But it was not a solution as the claims state. Me I am just going to replace the injector soon (preventative maintenance) and stick to just oil and keep the $65-80 extra in my pocket.
Solutions
Solutions
Have you tested your Ficm?
Cant say for sure if it helps or not, not enough use by me to know personally. Like anything else some will claim it helps other will laugh at it. My BIL does swear by it and he is rough on his trucks, so there is one that says it works. There is another product out there archoil and it is 1/2 the price for the same effects! Anyhow to add or not is a personal choice, just like asking a towing group if you 1 should own a ford 6.0, 2. put in a programmer or anything else. Only you you can make a reasonable decision and only after you try it. I run a oil bypass kit and the filter gets changed every other oil change at $35 a pop (amsoil filter) . Is it worth it or the initial investment? I figure it is, but there were other threads like yours asking about adding one and replies were similar in response some said yes some said no! I also run the T6 now, tried the amsoil stuff results are about the same with both, but again that can start a brand argument so its all up to you in the end.
rev x sorta works!
On my wife's 2006 f250 6.0l it has a cold start problem. I bought 2 tiny jars of rev x and put them in at oil change. 10w/30 synthetic. Seemed like it started better for about a week, then slowly got back to rough start up. Just changed oil again @5k miles 10w/30 synthetic and engine stumbles and sometimes won't start for 4 -7 tries. Plugged it in for two hours and it starts like brand new. I don't think I will buy more rev x..
