Cab bolts
Can't help you with the bolt size, thread or length, but the bolt threads normally into a nut and can be removed after the threads are disengaged.
But I suspect you are really wanting to know how to separate the two halves of the bushings, for which you need to create a pulling device to do so. Pounding the bolt head from inside the cab is futile and a recipe for broken things, like fingers and stuff.
Do a search on 'body bushing' and you will find lots of advice and solutions.
FordFETruck
10-21-2015 08:05 AM
514 ford stomper
1997 - 2003 F150
08-03-2008 08:30 AM
graymule
03-23-2004 07:04 PM
