uk f3 ambulance
Old 02-13-2013, 07:59 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Originally Posted by swellof64
..now you mentioned 2 speed transfer case? having not driven mine yet i presumed it was a 4x4 engagement lever[4x4 or 2x4] can you tell me which position is hi +low? thanks chris
Thanks for the archive data. I'll add it to my log. Good to know these were built in South Africa.
The below picture shows the shift pattern with Hi range being forward on the long lever, and Lo range back toward the seat. The short lever that sits between the driver's legs is the engaging lever to move from 4x2 to 4x4. Stu
Edit - It occurred to me that you might have the older style brass plate (and transfer case) that says "Positive" and "Compensating". The below old thread contains an explanation of that function provided by Chuck Mantiglia of Chuck's Trucks in CT. Stu
https://www.ford-trucks.com/forums/9...-52-f2-mh.html
Old 02-15-2013, 02:18 PM
swellof64's Avatar
swellof64
swellof64 is offline
hmmmm... i dont have 4x4/2x4 lever anywhere. does that mean i have permanent 4x4? will i save fuel if i disconnect front prop shaft , as im mainly driving on tarmac?
Old 02-15-2013, 02:31 PM
fordf350camper's Avatar
fordf350camper
fordf350camper is offline
Thats really nice i am in the Uk to
Old 02-15-2013, 02:43 PM
truckdog62563
Hmmm. Now I'm stumped. I'd suggest emailing Chuck, unless he stops by here to comment. Full time 4x4 is a possibility I'd guess. Stu
Old 11-25-2015, 04:18 PM
Bikelikealocal's Avatar
Bikelikealocal
Bikelikealocal is offline
Hi just got one F3 M/H 1951 Ambulance that needs a little love i hope that it;s ok to contact you, right now i just want to say hallo from Denmark, mine are similar to the one from the civil defense 6cyl with 4 gear, see you Hans J Grundtvig
Old 11-25-2015, 05:17 PM
truckdog62563
Welcome Hans. Glad to have you. Would this below linked for sale ad be your truck? Stu
Ford F3 Marmon-Herrington 4x4 paneltruck For Sale (1951) on Car And Classic UK [C588222]
Old 11-26-2015, 05:25 AM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
I will also add my welcome to the new members across the pond! Lets go back to the first truck, front diff on the left side as you look at the truck? That would make it a single speed transfer case truck correct Stu? How many levers should it have? Just the one between the drivers legs for in/out I would think. We need a picture of the floor of the truck. Maybe its just missing a lever.
Old 11-26-2015, 07:00 AM
truckdog62563
Differential on the left side, Mark, should mean it has a two speed transfer case. Wonder how many of these have survived, and wonder whether some pictured are actually the same truck. Hope Hans can tell us more about his truck. Stu
Old 11-26-2015, 09:32 AM
thundersnow70
hey stu,archive info...my brass chassis plate reads...... ford motor co [sa] belgium. f3hi 1951. chassis no..f3h1abx120980352. kg's.. 3083. yeh drive shaft goes to front axle on left as you look at the truck. number on long axle tube is 121o. mine is left hand drive. mh badges at rear of bonnet\hood no numbers. now you mentioned 2 speed transfer case? having not driven mine yet i presumed it was a 4x4 engagement lever[4x4 or 2x4] can you tell me which position is hi +low? thanks chris
Says drive shaft goes to front axle on left side as you look at the truck. Would that not make it a single speed? As I read it I assume he is standing in front of the truck, left side makes it the passenger side.
Old 11-26-2015, 11:09 AM
truckdog62563
Yup, that's what he said. You can read better than me. Stu
Old 11-26-2015, 11:33 AM
thundersnow70
So do R3-4s, the single speed transfer case trucks, have only the lever in between the drivers legs? Thats probably a bad question as maybe some of those trucks had the cross shaft to move the lever to the pass side.
R3-4 single speed t case............1 lever, passenger side front diff
R32-4 two speed t-case.............2 levers, drivers side front diff
Is that correct?
Old 11-26-2015, 11:50 AM
truckdog62563
Is that correct?
The R3-4 has one lever to the right of gear shift. The R32-4 and bigger models having two speed case have the lever between driver's knees. That's the in/out lever. The first I have record of use of the cross shaft for the two speed was the '53 F-250/M254. Stu
  #28
Old 11-26-2015, 11:59 AM
thundersnow70
It makes sense now that I think about it. The single lever would be to the right of the trans shifter. With the front output of the single speed t case on the pass side everything would be from center to right on the case. Clear as the new wind driven snow!
  #29
Old 11-26-2015, 12:04 PM
truckdog62563
Got a lot of that here lately! Stu
  #30
Old 11-27-2015, 04:20 PM
Bikelikealocal
hallo Stu.Youre right it is my truck now, in a fine condition, i feel so lucky, Hans
Quick Reply: uk f3 ambulance
