Anyone try to replace P90-100 CNG regulator with P90-75?
Old 02-03-2013, 08:54 PM
baskervi's Avatar
baskervi
baskervi is offline
My p90-100 regulator on my 2003 F150 7700 is bad, but I found one from a van that supposedly only had 60,000 miles on it before it was totalled. Both are from 3,600 psi systems, but the one from the van is a couple years older that had a compuvalve. The fittings look identical, except the vent valve placement is slightly different. I can't find what the low pressure side is on the P75-100, but this can apparently be adjusted if necessary.
Has anyone attempted this replacement before? Thanks
demarpaint
08-30-2012 12:43 PM
ooCHICOoo
10-04-2010 01:18 PM
HENDEL
08-03-2007 03:01 PM
demarpaint
12-21-2005 05:31 PM
dgeist
06-26-2004 04:57 PM
Quick Reply: Anyone try to replace P90-100 CNG regulator with P90-75?
