Best plugs for 5.4L
Just making sure: you do know about the issue of the plugs breaking in two and the extraction tool that you would need to do this job right? As for the replacement plugs, I have not read of too many using e3's on here. There is a champion plug that some have had success with. It's selling point is that it is a one piece plug that won't break on your next change, but some have complained of their truck not running as good on the champions, others say it is fine. Or or course you can just go back with motorcraft.
Yes I have heard about them braking. I have 69,990 miles on this new to me truck. I started using injector cleaner on the last tank and I will use more this fill up.
So just get Motocrafts? are the one piece now?
Is this the right tool?
Thanks, I will order the tool. I have never been a fan of champions but I do not like the idea of the two piece plug. I looked at the E3's and they are one piece, I just do not know how they would run in the truck.
Is 10-11 MPG normal for local short hilly driving with this 5.4L truck?? I just did my first fill up since I picked up the truck with a full tank and it is about 10 give or take MPG. I hope it will not stay like this!!!!
The following users liked this post:
i just changed my [champion] plugs cuz i had a constant misfire/rough idle at 210,000 km. 6 came out no problem but two squeaked and creaked and took twice the force but none broke! luck or cuz of champions??
it already had champions in it for how long i dont knwo but it was misfiring and one plug came out with a completely burned off electrode
