351w stalls randomly
Old 02-01-2013, 08:12 AM
gildardo01's Avatar
gildardo01
gildardo01 is offline
hey there... i hope you guys can help me out a bit.. i have a 91 ford with a 351w carburated.. and it tends to stall when its hot outside, or when i´ve been driving for about 20-30 minutes... it has a 4 sp tranny and it only stalls when it has to idle such as when i come to a stop or i put it in neutral, but while its in gear it runs fine, i don't notice any problems.. when it stalls it starts right up with no problems, i just have to give it some has so it will stay above idle to prevent it from stalling again... i just recently change the fuel pump because fuel was coming out of the weep hole.. and stalling issue was going on before i changed the fuel pump.. i was thinking it could be the problem with the ignition module but, either it doesn´t have one or its some where else besides the usual spot on the inside part of the fender... btw it has a oem points distributor... thanks for the help.. oh and the fuel filter is new so its not clogged..
Old 02-01-2013, 10:40 AM
Conanski's Avatar
Conanski
Conanski is online now
This truck was originally fuel injected, is it still using any part of the high volume/high pressure fuel system?
Old 02-01-2013, 11:40 AM
gildardo01's Avatar
gildardo01
no it does not have any original high pressure fuel acc... it has a mechanical fuel up going into a 2 barrel carb... at first i was thinking it could also be vapor lock but if it was i would have trouble restarting the engine... any ideas? thanks
rodp14
10-10-2017 05:13 PM
Logan Adams
03-12-2017 07:40 AM
fjazzbass
09-01-2015 12:44 PM
davidkeithwhite
1997 - 2003 F150
10-04-2011 08:26 PM
Mr13mcgoo
05-01-2009 08:38 PM
Quick Reply: 351w stalls randomly
