radio frequency interference thingy?
Ok so I was taking my truck apart and I managed to destroy this thing that was attached to the front timing cover bolt. There is one on both sides and I think I found it in a post somewhere on here. It's called a radio frequency interference capacitor or something like that. It's right at the end of the wiring harness on both sides of the engine just connected to a metal tab. Does anybody know what this is and where to get one? I can take a pic if needed. I know my description kind of sucks.
Thanks guys
Thanks guys
I went to a Ford dealer and they did order me one. It was $9. I wasn't going to worry about it but I have some threads online about engines not starting until they unplugged them. I don't know why that would cause a no start issue but for $9 it's not worth the risk. Thanks for all your help!
I'm sure your not going to fully understand but here is the way it works.
The coils cause a huge inductive 'kick' in voltage called a spike when their circuits are 'opened' each time to fire the coils.
The capacitors, one for each bank absorbs the spike to a large degree.
If this is not done the spike voltage radiates to other parts of the harness and can upset computer processing, allow noise in the radio and to others outside the engine bay.
They are subject to engine bay heat as high as 275 degrees and can go faulty over time by losing capacitance, go open or shorted.
If they go shorted, likely would blow the fuse powering the coils and injectors.
Open, cause rough running.
These devices do the same thing as a single condenser in an old points ignition to greatly reduce the 'arc' produced accross the points contacts.
They have to have a very high voltage rating of thousands of volts to handle the 'spikes' even through accross only 14 volts DC.
Good luck.
Good luck.
The following users liked this post:
Bare Wire Short at Radio Condenser - '94 F150
During a driver's training trip with my daughter, I had her pull to the side of the road so I could manipulate the plug wires while the engine was running to see if we had a shorting plug wire. While inspecting the coil wire plug at the coil, I unintentionally bent the wire to the Radio Condenser, which happened to have 1/4" of exposed bare wire at point where it enters the top surface. This bare wire contacted the outer edge of the condenser's case and the truck immediately died.
A 20 AMP Maxi-Fuse blew. It controls the coil I suspect. Replaced it and we were down the road.
That condenser is not readily available so a nickel's worth of RTV to seal the wire solved that issue.
Although this fixed the miss, I installed a new coil for good measure. The old one looked original anyway and the truck shows 209,000 miles.
Incidentally, the plugs, cap, wires, EGR Valve, vacuum hoses, etc, all look new. I suspect the previous owner changed them in an attempt to fix this miss. I got lucky.
Fuse 33
Good luck.
Good luck.
It sounds like that is what happened to me. Fuse 33 (controls ignition coils, shift solenoid and I think CMC #12 and #22 (whatever those are)) in my truck kept blowing as soon as I tried to turn the truck on. Truck would continue to crank but never start. Long story short, with the help of a techy friend, we discovered it was the coil capacitor aka ignition transformer capacitor, aka radio ignition interference capacitor on the drivers side. Unplugged it and the short went away. Truck starts up with no issues now. I have not driven the truck yet; I will wait for the replacement part. Not sure if it's OK to drive it or not as is.
