ARP part number for flywheel bolts?
I was wondering if anyone happens to know what the part number is for arp's flywheel bolts for my 360 .
I just pulled the beast out of my F100 to do a oil pan swap and a clutch/flywheel cleaning . This is part of my restoration/get the truck road worthy . I would like to replace the old stock bolts with new ones - also does arp sell the bolts that attach the pressure plate to the flywheel - if so what is that part number .http://www.martelbros.com/cgi-bin/st...ge=arp/arp.htm
I looked on that site and didnt see anything for the FE.
Try
http://www.arp-bolts.com/
They will show everything they have.
of try jegs.com
That's where I looked up my stuff.
Also... I lost mine on my 390 when I was rebuilding them.
I went and got some Grade 8 bolts and used them. I bought bolts that were a bit to long, and they didn't have any shorter, so I put a small washer behind them. Seems to work ok...
of try jegs.com
SWEET thanks guys - now if I could only find the correct 4x4 oil pan !
I was thinking about getting a 428 crank and flywheel and some 390 rods/piston's but I think that will get a little expensive - gasoline I mean
Besides the 360 is very new so why rip into it again- this is going to be my back and forth to work truck .
I would like to point something else out - my block D4TE has holes that almost look like it was cross bolted - but the holes are not through all the way and they are only on the passengers side of the engine .
Anyone know what these holes are? factory mess up?
[B}I would like to point something else out - my block D4TE has holes that almost look like it was cross bolted - but the holes are not through all the way and they are only on the passengers side of the engine .
Anyone know what these holes are? factory mess up? [/B]
I saw tranny cooler lines clamped down using these holes once (once only!) but whether or not that was stock I have no clue!
Thanks guys _ I have a line out on a stock 4x4 pan .
Anyone know if the miliden dipstick will work on a stocker and if so what is the part number (gidde up)
Thanks again
Thanks again
Originally posted by Gidde Up
The Milidon dipstick is a screw-in type that goes directly into the pan. The stocker, as you know, enters from the block and is a push in type. You'll have to try looking for something like a chrome dipstick if you are going to use a stock oil pan. And that is only if you wish to replace the stock dipstick.
"Highboy", too, now that I've been to this site
ak
I have a lead out on a stock 4x4 pan for cheep ! It isnt rotted out or rusted so why buy a $200 oil pan .
I wonder if I can modify the old 2wheel drive dip stick to work with the 4x4 oil pan . I am sure I will find something.
Go to a junkyard and look around until you find one.
ak
displacement4me
02-02-2009 08:01 AM
