V-6 Eco Boost swap into an Ex (someone please try it))
#33
If you maintain the v10, only use ford filters, coolant and the motorcraft blend oil... It make take you forever before doing a swap!
#34
As an example: my 1970 impala with the 400 small block, turbo 400 transmission, 2.37 rear end, and 2 barrel carb will fetch 15-16 MPG on the highway at 70-75 MPH. That's a big car with a big engine and no overdrive.
#35
Typically bigger engines with more torque kept to low RPM and low load are more efficient than smaller engines that run higher speeds.
And, interestingly enough, that little V6 only makes 5 ft-lbs less than the V10 does, and it has an even better torque curve for towing. I used my truck to tow home a minivan for my mother-in-law; total trailer weight was over 9,000 lbs and I never got over 3,000 RPMs the entire trip. It was 52 miles each way with 40 of them being interstate. I hold lower RPMs with this thing than I did with my Excursion!
#36
Tom, you know as well as i do the V10 was never meant to hold low RPM's...when you want/need TQ you gotta run it up there, that's how it was designed. the V10 loves to sing along at 5,000 RPM.
btw, i was able to drive our new sales truck set up much like yours...your going to say i'm crazy but i was no impressed. i think maybe i expected to much? idk. it did lug around pretty good though.
#37
The EcoBoost is mated with an F-150 for a very simple reason.
It's basically a Taurus with a bed.
The EcoBoost will never end up in a REAL truck. Just because I can tow a sack of potatoes with my daughters Powerwheels Jeep doesn't mean it's a decent tow vehicle.
(Full disclosure: I'm kidding and if the Atlas comes out with a EcoBoost, I'll buy it)
