Don't you need a new core support for a nose swap? And going by your pictures you have a new bumper, the bumper trim, and the headlights-grill assembly correct? In case someone is wondering why I'm here, my mom has an X so i browse around. :P
You need the mounts from an 05-07, the old ones won't match up, they attach by the tow hooks and on the ends. I swapped mine out after my wife's wreck. Doesn't show the brackets but here's a link to my process. And header panel only, everything else is bolt on. https://www.ford-trucks.com/forums/1...pic-heavy.html
I didn't dot he 05+ bumper but in order for me to rebuild my 03 bumper to work with the 05 grill I had to cut the tops off the frame rail end cap thingies.
Here is a decent pic of the tops cut off the frame rail ends and how close the 05 grill comes to the frame.
Damn, I'm totally not getting this. Your thread looks so straight forward, but mine is totally not like this Am I able to use the OEM fog lights or no?
Oh yeah I see the pic with the 02 bumper bracket now. You need to get all the 05 bumper bracketry. I used my 03 bumper and did all sorts of cutting and welding to make it work with the 05 grill, header panel, and whatnot.
Can someone shoot me a link to some well priced brackets and the best options for fog lights? I might skip OEM and go for something aftermarket lights.
