Lowering rear of my 56
Old 01-23-2013, 03:06 PM
Haroldmac's Avatar
Haroldmac
Haroldmac is offline
Going with fatman front suspension on my 56 f100. I,m really wanting to go as low as i can with this truck. That being said, as far as the front i would maybe get the 2 inch drop spindles to go with the fatman. Fliping the axle on the rear, if i need too maybe remove some springs also. How low can i go on the rear without getting into a lot of issues? Planning on c-notching rear frame also. If i went with the drop spindles on front would i be abe to match the rear by just the axle flip , c-notching and removal of some springs? Thanks HaroldMac
Old 01-23-2013, 04:09 PM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
I also have 2" drop spindles on front with mustang II. PUtting heidts crossmember on first weekend in feb. Also curious about c-notching rear end. Would love to hear what the Pro's have to say
Old 01-23-2013, 05:10 PM
Haroldmac's Avatar
Haroldmac
jrockdiddy how low did the drop spindles get your front? I would like to go ahead and do them as i working the front. I have had some tell me to wait and run the stock ones first. But i can send the stock spindles in on the drop one if their still new. Also what size tires are you going to run? Thanks HaroldMac
Old 01-23-2013, 05:18 PM
jrockdiddy's Avatar
jrockdiddy
I have 17" wheels, looks ok, wanna go with 20's. I'll send pic.
This is only one I have. Before heidts crossmember
Old 01-23-2013, 05:41 PM
Haroldmac's Avatar
Haroldmac
What have you done to the rear suspension so far?
Old 01-23-2013, 05:43 PM
Rich56's Avatar
Rich56
Rich56 is offline
Nice job Jrock.
Little advice, once that truck is finished and painted, rearrange that garage wall, it's an accident waiting to happen, trust me, I know.
Old 01-23-2013, 05:53 PM
fatfenders's Avatar
fatfenders
fatfenders is offline
Drop shackles and losing a few leaf springs is a great way to lower it. Will ride and handle fine. 4 springs will put you in the weeds. 5 better if you are going to use the bed. I have run both, 4 leaves the last 5 years. I am throwing the fifth back in when I get a minute. She sits a little lower than she once did. One leaf will usually raise or lower under an inch, give or take.
Old 01-23-2013, 06:12 PM
jrockdiddy's Avatar
jrockdiddy
Haroldmac, Lincoln rear end on rebuilt leaf springs. Kinda 4 link but its all show. Not beneficial. PO work. Gonna c notch I think.
Rich, yelp garage is a ***** storm. Truck should have its own garage end of this year or early next.
Old 01-23-2013, 06:14 PM
Haroldmac's Avatar
Haroldmac
Thanks for the info. I really do want this thing low. Its not like its going to be my everyday driver. I have always wanted one slammed. I think i will go with the swap out of the spindles and catch the rear up with it. Where do i start getting into the bed? Will axle swap to top and taking out of a few springs be getting close? Thanks
Old 01-23-2013, 06:22 PM
fatfenders's Avatar
fatfenders
With a No Limit drop, and four leaves, no C channel, mine sits low as I would ever want. No driveabiity issues but plenty low. I have never bottomed out, but rarely have any cargo in the bed either. I can measure or take PICs when it isn't 0 degrees out if that would help. May be some iPICs n my old galleries. The No Limit Engineering drop shackle is a very nice piece. I think you want to order that for sure.
Old 01-23-2013, 06:24 PM
Haroldmac's Avatar
Haroldmac
Well the ride height looks good. I,m thinking of going with 18s. I really dont want to tub the floor. But like i said, the truck will not be used to haul nothing but my a**. Just want everything to come together at once. Got to get all this behind me before i start on the looks. Looking at hot rod black. Still too far away to say yet. Thanks again
Old 01-23-2013, 06:31 PM
jrockdiddy's Avatar
jrockdiddy
My rear needs to get a lot lower. I'm gonna check out fatty's no limit drop shackle
Old 01-23-2013, 06:33 PM
Haroldmac's Avatar
Haroldmac
Thanks Fatfenders. I will have to check that out tonight.
Old 01-23-2013, 06:42 PM
fatfenders's Avatar
fatfenders
what size tire is that jrock? Nothing some more drop and more rubber wouldn't cure.
Best advice I can offer for most any nod is "find the line". Don't care if you are lowering, buying tires, making more HP, whatever...
There is almost always a line that if you cross, the downside becomes not worth the small amount of good you think you are gaining in looks.
Hear me know, believe me later.
Old 01-23-2013, 06:52 PM
jrockdiddy's Avatar
jrockdiddy
245/45zr17
Quick Reply: Lowering rear of my 56
