running horrible out of nowhere
suddenly my truck is running like garbage. at low rpms it bucks, vibrates, and surges and just has no *****. at higher rpms it seems to clear up and run fine. i am frustrated because almost everything on this truck is new or relatively new. cap, rotor, plugs, wires, air filter, all that tune up stuff is always kept on top of. plus tons of other things like the fpr, coolant temp sensor, every vaccuum line, its too much to list. i have two suspicions:
1. my exhaust manifold leak is getting worse. is it possible that the gasket blew out so bad that its affecting the intake manifold?
2. the iac valve has been acting up despite the fact that its a motorcraft and i replaced it about 6 months ago. the truck screams when its cold, and i mean screams (about 3500 rpms).
Click this link:A9x ECM's (and same years ECM's) Failures Due to Age
Several of us out here are in agreement that the computer/EEC/ECM/PCM or whatever term you'd like to use, WILL EVENTUALLY fail on these older trucks.
You can replace everything under the hood, but, if the computer is toast you'll be pizzin' your money away on the wrong thing(s).
Also, grounds are VERY important on the 4.9's
I't be wise to find all your ground points and clean till shiny and closely examine the negative battery cable.
A resistive ground(s) will throw the truck into complete chaos as far as driveability.
Keep us posted.
Bob
Answer to #2: I doubt the IAC is at fault here. You could have a vacuum leak (if the theory in #1 holds true, this is very plausible), you could have an unrelated vacuum leak or there is a sensor sending wrong info to the PCM. You stated you replaced a bunch of sensors but did you ever test the old ones?
Have you checked for codes? Even without a Check Engine Light on there can be a failure and/or stored codes.
Here's something to check that may explain everything.
Keep us posted.
Bob
Keep us posted.
Bob
Answer to #1: Yes it is possible that could have happened. Rare, but possible. To top it off any exhaust leak upstream of the O2 sensor will make the PCM think the truck is running lean. In turn it starts dumping in more fuel.
The good/bad news is that they will still function as they fail; complete failure seems to take a while. Try not to wait that long.
1996cyl
25
03-24-2011 01:05 PM
