Help Cluster
Old 01-20-2013, 10:03 PM
fordalltheway818's Avatar
fordalltheway818
fordalltheway818 is offline
Help Cluster
Hello guys. Well I got a 1960 F100 and im putting in a 2000 ford lighting motor in it. I already have the motor with tranny and wire harness and all that good stuff. The issue im having is how am i going to hook up the cluster with the new harness. Do they sell a kit that could go in the truck and wire up to harness or do i put in the lighting cluster in it? I would really appreciate it if guys can help out. Thanks
Old 01-22-2013, 09:27 AM
3414's Avatar
3414
3414 is offline
With that engine and transmission you might not have a place to connect the speedometer cable, the 2000 trucks used a pickup on the rear axle to drive the speedometer.
Someone might make an adaptor or input device to get you a mechanical connection if you want to use the old speedometer.
On the old gauges - they will work with the Lightning engine if you put compatible (old style) sending units in the engine.
It might be less work to adapt the gauges and speedometer from the Lightning cluster to the old cluster.
Old 01-22-2013, 10:02 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
fordalltheway818; welcome to the forum. not much help for you here, but I would like to follow your progress and we all like pictures.
Old 01-23-2013, 09:37 PM
fordalltheway818
Thanks for the info i really apreciate it. I will post pic as soon as i start
Not Fragile
04-27-2023 01:55 PM
mysherona
09-17-2015 08:30 PM
bhami8287
11-10-2009 09:53 AM
propaneman
10-20-2008 11:33 PM
evin
04-14-2004 10:17 PM
Quick Reply: Help Cluster
