1972 f250 highboy axel
I am currently looking at a 4x4 1972 ford f250 highboy. I plan to swap the axels with outdated drum breaks to newer disc breaks, at least the front.( for more breaking power) Can anyone tell me exactly what axels I need to look for? Thanks in advance.
P.s. they are 8lug axels.
A 1979 F250 Dana 44 front axle would be almost a direct bolt up and fairly inexpensive ($300). They have disk brakes and have a high pinion reverse cut gear set. This is probably the option you will want to go with.
If you are running BIG tires you will want to look for a Dana 60 out of a 1979 F350, but these are becoming very hard to find and expensive (1000+).
I think that unless you are doing a lot of hard off-road or rock crawling you will be OK with a Dana 44 running 35's
A Dana 44 front would be fine with 35s. The 76-77 1/2 might be a nice option for you also, but I am pretty sure the 78-79 Dana 44 axles utilize kingpins which is nice (I know the 60's do at least) and as mentioned is a high pinion. 78-79 is the superior axle, but like was mentioned the 76-77 1/2 is a direct replacement.
The Dana 44 we are talking about are both F-250 3/4 ton axle's, just different year model's. Eight lug that mount with leaf springs.
cooperstown24
15
01-14-2019 02:18 PM
74F2504by4
01-30-2018 02:38 PM
1972fordhighboy
02-20-2015 02:00 AM
