6.2L V8 Discuss the 6.2L V8
Water temp
Old 01-19-2013, 09:17 AM
jorlee's Avatar
jorlee
jorlee is offline
Water temp
What is the water temp susposed to run on these things?
Since it's been cold (under 30), I see about 180 max and see drops down to 172 when decelerating. I'm wondering if my gas mileage is suffering, because it's not warm enough. I gained 1mpg with my 6.0 diesel with a new thermostat, when it wouldn't get above 180 and stay at 190.
Do I have a defective thermostat? or are these things cooler running?
Old 01-20-2013, 05:33 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
How do you know the water temp? Are you using a Scangauge?
Old 01-20-2013, 05:36 PM
jorlee's Avatar
jorlee
jorlee is offline
Yes, a scanguage.
Old 01-20-2013, 09:13 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
That sounds about right. When I was at the Ohio meet, my water temps never escalated over 215. That was flat out, uphill with 15k lbs + behind it for a mile or so. Fans never even came on.
I'll try and remember to monitor it some tomorrow when I'm running errands.
Old 01-21-2013, 05:56 PM
jorlee's Avatar
jorlee
jorlee is offline
Today's findings are after 3 miles it peaked at 188 then dropped to 177 in half a mile, and held til I came to a stop 7 miles later and it dropped to 168. Did the same on the return trip. Would only come up to 177 after a few miles.
Heater shure felt great at that 188, not so much at 170.
Old 01-22-2013, 10:31 PM
Flatbed Ed's Avatar
Flatbed Ed
Flatbed Ed is offline
My Edge CS Monitor shows 205 most of the time. That is the cylinder head temp. It won't show me the water temp.
Old 10-10-2013, 06:01 PM
jorlee's Avatar
jorlee
jorlee is offline
Anybody else have water temp readings? Dealers don't want to mess with it till it gets colder.
I'm ready to trade back to a V10, 5.4 or a newer Dodge? What's the best deal?
Only reason I went to a 6.2 was the get the 4 door and a gas for faster heat in winter. Most my miles are in the winter.
Old 10-10-2013, 06:06 PM
senix's Avatar
senix
senix is online now
Received 1,420 Likes on 1,014 Posts
Put a cover on it or is there room to put a piece of cardboard in front of the radiator?
That is what I used to do short of the cover.
Old 12-09-2013, 03:56 PM
jorlee's Avatar
jorlee
jorlee is offline
Update, put in a napa thermostat today. Went for a short 1/2 mile drive due to visibility. Had readings of 191-197 degrees. Not long enough to really tell heat output but should be way better than the 179 high I had going to NAPA. Will update if gas mileage also increases.
Old 01-25-2014, 04:26 PM
jorlee's Avatar
jorlee
jorlee is offline
Wow, depending on wind direction I now see 193- 197 degrees. Feels like a Ford again (having to turn down the heat since it gets quite warm now).
I do would say for certain my MPG's have climbed back to a respectable 13-14+ for winter.
Old 01-25-2014, 05:57 PM
senix's Avatar
senix
senix is online now
thanks for reporting back that you fixed your issue.
grantpage
09-11-2012 08:09 PM
Bbasso
Modular V10 (6.8l)
08-20-2011 06:00 PM
Oversize
09-21-2009 09:20 PM
89broncobob
1978 - 1996 Big Bronco
07-06-2003 07:08 PM
Quick Reply: Water temp
