It is wicked easy to do. The kit comes with a paper cut out that helps you line up the holes. My advise is to put a wooden block under the front of your headliner to give you a good gap when you drill and measure a few times.
Which kit did you use that has the paper cutouts to help you?
I got the factory kit off of a guy on ebay. I know the dealers are usually wicked expensive to buy the kit off of, but if you search ebay you might find one.
